Some question on setting priority
i like the priority feature and always use it for each version . but i noticed 1 thing that i dont understand
setting priority to very high makes that particular episode finished faster since most data downloaded will be from that episode i understand this . but what about setting it to high ? i tried it with all normal and 1 high but they all download distributively only very high affect the data downloaded . setting a very high a high and other normal is also equal to setting a very high and other normal . the priority high does not seem to prove it usefulness since it only the same as normal .
very high , high,normal,etc are relative to each other…
they will make difference when say there are 3 tasks running - one with very high , 2nd with high and third with normal…then the difference will be evident…
if you have only one task…then it doesn’t matter whether it is very high, high or normal…
or
if there are three tasks all with high priority…even then priority wont show effect coz relatively they are at same priority level which same as having all the three tasks at normal priority
Your local initiated connections will request data for files set to very high first, then high, then normal. You might not notice much difference between high and normal.
Incoming “remote” connections will have no effect.
