Can any kind souls help with me with regards to the settings for bitcomet 0.68 when using with kerio & Avast??
Currently running on XP SP2…
I’ve just switched over from Mcafee and the d/l speed dropped from 80 to 5…
Thanks ![]()
Thanks ![]()
What McAfee program are you using? If it’s personal Firewall you need to set BitComet for server access.
I’ve just switched to kerio firewall…even the internet speed is seriously slowed…i tried to adjust avast but still to no avail.. ![]()
Yeah!
I use Kerio Personal Firewall and I have the same problem. My transfer are usually 5-10 kB/s. Sometimes very rarely it is about 30 kB/s but obly for a few seconds.
Regards.
Maybe some pictures will help u set up Kerio
First of all make sure resolve address is disabled
settings
Hope the pictures help ![]()
And to be sure that Kerio is the problem with your speed and not just the torrents your downloading
Here is a torrent you can test that should be really fast.
http://distribution.openoffice.org/p2p/
Also in the peers tab make sure you are getting remote peers. If they are all local that means something is blocking incoming connections
Wow…Thanks a million…the d/l speed has increase significantly even while i’m surfing… :lol:
Another question…i’m currently d’l 5 files…but it seems like only 2 files are d/l at 60K and above while the rest is not moving at all..even when status shows downloading.
And in the seed/peers column, i can have 2k plus of peers but only connected to less than a hundred..did i set anything wrongly?? :unsure:
Many, many and many thanks
Your torrent went with >200 kB/s. So it is not problem of system, program or any of my firewall. Now at least I know I have very bad other torrents. Thanks a lot. Ufff now I can take it easy.
Hmmm…i think i might have a problem here…the sample d/l site doesn’t seem to work for me though… ![]()
BTW how do i check the peers status?? :unsure:
