soporte para mega? se sabe algo?
Hecho de menos en este programa soporte para descargas de mega como en otros que ya estan saliendo..
lo cual me obliga atener varios instalados, antes siempre preferia bitcomet…
se sabe si se añadira soporte para descarga de mega?
I miss the support for the download of “mega” with this program, as can be seen in others that are already being released… which forces me to have various ones installed… Before, I always preferred using BitComet.
Does anyone know if the support for the download of mega will be added?
Perdona pero, ¿a qué te refieres con “soporte para descargas de mega”? Me temo que tendrás que explicarte un poco más…
I’m sorry but, what do you mean by “support for the download of mega”? I’m afraid that you’ll have to explain yourself a bit more…
My guess is he’s using a site like megaupload and not only assumes everyone knows what he’s talking about when he calls it “mega”, but even more ignorant is to think it is bitcomets job/decision to support that website.
I don’t know how to reply to someone who cannot even explain what they want and if the communication is that bad, how are we going to even begin a dialog about the reasons why they aren’t able to use bitcomet.
Archivos alojados en servidores MEGA, no son archivos descargables via protocolo http ni via protocolo torrent
Files hosted in MEGA servers, they are not files downloaded neither http nor torrent protocols
What are “MEGA files”?
It’s times like this - when I have to guess at what they’re talking about - that you’ll see me asking them to explain what they mean… it’s hard enough to translate jargon and slang terms (which can vary greatly, depending on which country the poster is from), without having to guess what they’re talking about.
What irks me, though, is, if they speak both English and Spanish (sometimes they’re more fluent in English than in Spanish), why do they insist on having me translate? Do they just want to practice/test their Spanish skills (or mine…LOL)??
pues yo lo que quiero saber es como hago para tener el VIP acelerator pleaseeee
Well, what I want to know is what I have to do to get the VIP acceleration, please.
Buenas noches.
Cuando los puntos de tu cuenta sumen 40.000, podrás pedir éste servicio gratuitamente. También puedes comprar uno de los “paquetes” que se ofrecen aquí.
Has de tener en cuenta, sin embargo, que este servicio no te servirá para aumentar la velocidad máxima de tu linea de Internet… es decir, si tú tienes contratado un máximo de 10 Mb con tu proveedor (Movistar, ONO, Jaztel, etc.), ésta velocidad no va a aumentar milagrosamente. De todas formas lo puedes probar y si tienes problemas, nos lo puedes contar aquí mismo.
Un saludo. :slight_smile:
Good evening.
When you have reached an amount of 40,000 points in your account, you can ask for this service, free of charge. You can also purchase one of the “packages” that are offered here.
You have to know, however, that this service will not serve you to surpass the maximum speed of your Internet connection… this is to say, if you have a connection of 10 Mb maximum with your ISP (Movistar, ONO; Jaztel, etc.), this speed isn’t going to miraculously increase. In any case, you can try it and if you have any problems, you can tell us about it right here.
Regards. :slight_smile:
