ok ive used bitcomet before but i ended up deleating it becuse i got faster d/l speeds from normal p2p downloads… i was just wondering is the speed of a download limited as the highest i got today was 35kb/s and that was for 3 seconds untill it went down to 15kb/s then lower it sorta wavers between 5kb/s and 24kb/s so yea is this natrual or just plain slow?? and is there a way to speed it up?? :rolleyes:
I have had speeds near 800kB/s, but generally I’m happy when speeds are above 50kB/s.
When you take the time to learn how bit torrent works, you will agree its far better then other methods of downloading.
Did you foward your ports and use the speed guide?I get between 50-300kbs dl and give 80-92kbs up after i followed the guides. B)
