can you tell me if its possible to disable this from comet bird . My sister has an exam to do at home for her open university .They have told her to make sure this is disabled before she can do the test :mellow:
Please make sure to post in the proper forum.
topic moved
Right-click in the text editing are on the page you’re trying to write on, and from the context menu disable “Check spelling”.
That will work only for the current tab you are displaying. If you want to disable temporary the check spelling for all tabs, go to Tools > Options… > select the Advanced section, then go to the General tab and uncheck the Check my spelling as I type box. Finally, click on the OK button.
Have a nice day there! B)
thank you ![]()
