Strange,please help
:frowning: ok so the other day i open bit comet and i get this weird type on my screenwhenever i click on information
µçÓ° ÓÎÏ·
ÔÚµÄËÑË÷¿òÖÐÊäÈëÐèÒª²éÕÒµÄ×Ö´Ê£¬ÓÃÊó±ê×ó¼üµã»÷ËÑË÷¿òÅԱߵġ°ËÑË÷¡±°´Å¥£¬¾Í»á·µ»ØÄúÏëÒªµÄËÑË÷½á¹û¡£ ËÑË÷¿òÏÂÃæÓÐÈý¸öÑ¡Ïî°´Å¥£¬Äú¿ÉÒÔ¸ù¾ÝÐèÒª£¬µãÑ¡²»Í¬°´Å¥£º
ËÑË÷µçÓ°£º×îеĵçÓ°×ÊÁÏ, ÕâÊÇĬÈϵÄÉèÖá£
ËÑË÷ÓÎÏ·£ºÏêÏ¸È«ÃæµÄÓÎÏ·½éÉÜ¡£
ËÑË÷Èí¼þ£º(ÔÝʱ²»Ìṩ)
what the h*** is that?
We are aware of a bug that has the internal search function default to chinese language. Since you don’t have chinese language installed, you are seeing this code displayed.
I believe this is the cause, an this should be corrected in the next version of bit comet.
In the mean time I suggest you use your browser to do the searches, or install a previous version of bit comet.
