hi.i use bitcomet 0.70 and the past few days when i log on to bit comet and downloading smthng,the browser i use (firefox latest updates) gives me some mysterious messages like:
''This IP is being shared among many domains.
To view the domain you are looking for, simply enter the domain name in the location bar of your web browser.‘’
or
''Directory Listing Denied
This Virtual Directory does not allow contents to be listed.‘’
or this
‘‘This is the placeholder for domain idpserver.net. If you see this page after uploading site content you probably have not replaced the index.html file.’’
I’m not sure why this is happening, but have seen simular errors as a result of addware/spyware.
I suggest you run the following programs
Spybot Search and Destroy (freeware)
Ad Aware, also free (beware of sound alike programs that will infect you rather then clean your system)
Also, since this may be a browser hijacker, I would run “xoft anti spyware” (very good at removing hijack malware), not free, but worth every penny (or download a torrent with keygen if you like)
only bulletproof found a trojan(i dont remember its name) which was succesfully removed.
i will try those you suggested me.
but why this happens only when bitcomet is online?
i installed xoft antispyware(ad-aware was already installed) i updated it and i scaned my pc.some cookies were found,nothing much.but it keeps doing it
i’ve been using bitcomet port forwarded for a long time but i have never face such problem again
Have you installed any Firefox addons recently? especially any with Toolbar in the name.
EffectiveBrand.com changed its name to Conduit.com and removed the “no spyware guaranteed” warnings from their homepage.
Could be a problem if you have an older toolbar of theirs since they changed domains fairly recently. If you have any toolbars for Firefox I would say uninstall them and see if that helps. Otherwise I guess if you post a HiJackThis log I could take a look.
I would like the rest of the staff and members to review this post, as I’ve not seen this problem before.
Feel free to send me a PM if you don’t get any replys within 24hours or so.
yep i have TABMIX PLUS and TORRENT SEARCH TOOLBAR installed.should i uninstall them?
the same thing happens with ie.nop any mods to windows
I would remove the toolbars (most are a drain on resources), and you can always reinstall them if you like their function.
ps. I removed your logs from the post and added them as attachments. Please use the attach file option to post this type of data.
i moved it and i killed commserve.exe.but i still get(more) wird messages when i run both bitcomet and firefox.like ‘‘the pafe is under construction’’ or a fake (i think from the logo design) google error(???)
i have already run:bitdefender pro v10
ad aware se pro
bullet proof spyware remover
spybot search and destroy
xoftspy se
ewido antispyware 4
all full updated.i fixed every problem they suggested.but nothing…
This program itself isnt necessarily bad but it can be used for bad purposes.
This thread should help you getting things cleaned up. Just worry about the things that apply to you and it is very important that your computer is in Safe Mode when cleaning up. Also you may want to disable System Restore while cleaning so that the trojan cant hide in there.
“commserv.exe → Trojan.Agent.ye” Dude, I have this same virus. You were absolutely right, it came as a keygen for BitDefender v.10. BitDefender was able to quarantine it, but for some reason I cannot delete it. Do I need to be in safe mode to do this? Were you ever able to remove it, and if so, how did you do it? Any help is appreciated, thanks.
The two of you should try Avast! free version and set it to scan at start up. It will run the scan and then load the OS so it should be able to get everything.
