Stuc in connecting to peers
i need solution pls
it won,t download anymore
/monthly_2019_05/SOLUTION.PNG.b19603bf5d3866cf15254e0d6d592879.PNG" class=“ipsAttachLink ipsAttachLink_image”>
You might just be better asking in the utorrent forum - this is for Bitcomet LOL
i am having same problem , the site says theres peers , but i cant connect to them , i am using avast vpn , and i still trying to use pirate bay for magnets , please help i just loooking for some old music .
Unless you’re also using utorrent, you won’t have the same problem
However, can you connect with the VPN off (normally a few seconds of a cobnnection won't trigger any alarms). Ifthat still fails, there's a possibility that there just aren't any seeds - I've had files sitting for ages with a lot of peers but no seeds (presumably all the others had the same amount of data that I had)
