Subtitles not converted
Hi there,
When loading the subtitles for a movie, display is fine. But when converting to a mp4 format for the iphone, the subtitles disappear. Am I doing something wrong or is MPC Star just not able to do it…??
Thanks.
MPC Star is able to play external subs. If your iPhone is capable of playing them, then you need to use a type of subtitle that it supports. Another option is to do your video encoding (converting) with “hard” subs. This is when the subtitles are encoded directly into the video, and hard subs cannot be disabled, but it might be your only option if the iPhone doesn’t support external subs.
You would need to look into your conversion software options to learn how to do this.
If this question is about MPCStar, it’s in the wrong forum.
But I don’t see how MPCStar is even involved in this. It’s just a Windows player and has nothing to do with the conversion for the iPhone, with or without subtitles.
Does this belong in the general questions forum?
(Edit) I am assuming that you used MPCStar to transcode the file to MP4.
That being so, I’m moving this to the MPCStar forum.
Conversions aren’t MPCStar’s strong suit, and I wouldn’t expect it to handle subtitles properly, when I’m not even sure how to do that for the iPod. I would suggest handling the subtitle conversion separately, after boning up on what you have to do. You may want to use something else entirely for the whole job.
This doesn’t belong in the bitcomet forum, but since the member has a poor understanding of English, I didn’t want to move it until they read the reply.
ps. I suspect this member doesn’t realize what program is doing their video encoding, or is unable to articulate it, since I’m unaware of mpcstar being able to transcode video.
I wasn’t either, but I checked, and it sure does. File → Converting Format
