Subtitulos mismatch.
Hi, I have problem with the latest version 5.3 The subtitle of mismatch. is a version problem or mine, how to fix it, thanks
Without more information as to what you mean by “mismatch”, I can’t really say, but it sounds like a problem with the subtitles, they have to be matched to the video you’re watching, If you get subtitles for a similar video, they might not be properly aligned.
