suggestion for bitcomet
Isn’t that better if we can set the downloading task based on sequences. What i try to say is something like… we set the first task, then the second task starts automatically after the first task finished and then the third task and so forth…
Its not better. Thats not how bittorrent works. Bittorrent downloads pieces and starts uploading them the minute it gets them. It gets pieces with the best responce team and works its way down from there. I don’t know if you ever used Kazaa, but what you’re asking is similair to the way Kazaa worked. And that network was slow.
