Hi,
Everytime I update BitComet I uninstall all previous versions and files and only keep the torrent files bitcomet saves into its torrent directory.
Unfortunatly, bitcomet does not save the information as to the download directory or the percentage of the files it has downloaded. Nor which parts of the file I wanted to download.
Would it be possible to integrate this into a new version?
That way, if you for some reason have to clean install BitComet you can open the torrent files saved by bitcomet and you will automatically have the right directory, the right percentages and very important, the correct parts. You don’t have to select all the internal aprts again.
Thanks!
