Tabs problem
In later versions of Bitcomet (1.23 has other problems, so I haven’t bothered further with it but 1.20 and 1.22 are definitely affected), the tab settings below the tasks window do not work properly.
Right-clicking on the tabs brings up a menu where various tabs can be selected and deselected, but some of the menu choices sometimes do nothing – If “Always show tabs” is deselected, the menu effects change so that some selected tabs – Trackers, Peers – do not appear when selected. Selecting/deselecting makes no difference for these, but works for others. This should be consistent across all tabs.
Reselecting “always show tabs” repairs most of this. What, exactly, is the function of “Always show tabs” supposed to be? Why is it here?
The “Connections” tab never appears under any circumstances. (I have never seen this tab).
The “Always show tabs” option sets all the tabs related to that task type to be shown regardless if the task is running or not or if a particular tab has anything to show (for ex. the snapshots tab).
The “Connections” tab is only shown when selecting a HTTP task.
