When you open many tabs within BC and when you close a tab somewhere in the middle of the row the next tab that is selected after you close the previous one is the right tab like it should be.
But when you close the last tab the next that is selected is always the first one.
It will be good to make it when you close the last tab the next one that is selected to be the previous tab that was open befor the closed one.
