When I start up (or auto start) the task are not running automatically, how can I make them run automatically each time bitcomet starts ?
thanks
thanks
go to preferences ==>appearance==> check auto resume task on bitcomet startup
That was clicked on already , now what?
Check the properties of your downloads.xml file in the BC program directory, and make sure it’s not set as read-only.
it wasn’t
Please always include version number with your requests for help
the latest version of course
If you are using v 0.73, you should downgrade to the last stable version 0.70
See the link above in order to download it. Later versions have a great many problems and instabilities, and are too unreliable to use.
