Just to be clear one more example:
No torrents are enabled. I press ctrl+n and enter absolutely any valid address. So I enter "http://www.microsoft.com/en-us/default.aspx".'>http://www.microsoft.com/en-us/default.aspx". It downloads and shows me spent time of two seconds. The logs are:
2012-03-20 01:19:21 Task started.
2012-03-20 01:19:22 default.html created.
2012-03-20 01:19:23 Task completed.
A bunch of upload torrents are enabled. Download and upload rates are near 5 kB/s both (so no real upload is in process). I press ctrl+n and enter "http://www.microsoft.com/en-us/default.aspx".'>http://www.microsoft.com/en-us/default.aspx". It downloads and shows me spent time of one minute ten seconds. Actually at 1:08 it was 0% of download and at 1:10 it was already 100% of download. During these 1:10 I have absolutely no problem accessing "http://www.microsoft.com/en-us/default.aspx" from browser, so that’s not a network problem too. The logs are:
2012-03-20 01:07:50 Task started.
2012-03-20 01:08:20 Start searching for mirrors…
2012-03-20 01:08:41 Found 0 mirrors .
2012-03-20 01:08:58 default.html created.
2012-03-20 01:09:00 Task completed.
Did it once more. And again 1:10.
2012-03-20 01:21:17 Task started.
2012-03-20 01:21:47 Start searching for mirrors…
2012-03-20 01:22:08 Found 0 mirrors .
2012-03-20 01:22:27 default.html created.
2012-03-20 01:22:28 Task completed.
If I reduce amount of upload tasks, the lag decreases. But usually it’s enough to have just one serious torrent task active to have 30 second lag already.
