TCP connection overflow
first…sorry for my english…is translation by google
Client:  Bitcomet 1.49
by longer idle time. the tcp connections can bump up to over 9000 (also in zero torrent active)
my setting problem or software problem?
Up Time: 0:00:15
Overall Tasks: Total: 0 / Running: 0
TCP Connections: Established: 43 [MAX:Unlimited] / Half-Open: 0 [MAX:200]
LAN IP: -------------
WAN IP: -------------
Listen Port of TCP: ----- (Opened in Firewall/Router)
Listen Port of UDP: ----- (Opened in Firewall/Router)
Windows Firewall: Disabled
UPnP NAT port mapping: Disabled
Disk Boost Service: Not Installed
Overall Download Rate: 4 kB/s [MAX:Unlimited] Max Connection Limits: 9999 per task
Overall Upload Rate: 1 kB/s [MAX:Unlimited] LT Seeding: 0 kB/s [MAX:Unlimited] All BT Upload Slots: 0
Memory Usage: Working Set: 121.46 MB, Commit Size: 74.13 MB
Free Memory: Physical: 55.44 GB/63.93 GB (Min to keep: 50 MB), Virtual: 53.75 GB/63.93 GB, Process: 127.96 TB/127.99 TB
Disk Cache Size: 0 B (Min: 4096 MB, Max: 16384 MB)
Disk Read Statistics: Request: 0 (freq: 0.0/s), Actual Disk Read: 0 (freq: 0.0/s), Hit Ratio: 0.0%
Disk Write Statistics: Request: 0 (freq: 0.0/s), Actual Disk Write: 0 (freq: 0.0/s), Hit Ratio: 0.0%
Total Downloaded: 92.54 GB (this session: 64.28 KB)
Total Uploaded: 122.69 GB (this session: 25.19 KB)
Up Time: 1:02:53
TCP Connections: Established: 1800 [MAX:Unlimited] / Half-Open: 0 [MAX:200]
LAN IP: ----------
WAN IP: ---------
Overall Download Rate: 18 kB/s [MAX:Unlimited] Max Connection Limits: 9999 per task
Overall Upload Rate: 2 kB/s [MAX:Unlimited] LT Seeding: 0 kB/s [MAX:Unlimited] All BT Upload Slots: 0
Memory Usage: Working Set: 181.89 MB, Commit Size: 162.78 MB
Free Memory: Physical: 52.98 GB/63.93 GB (Min to keep: 50 MB), Virtual: 51.09 GB/63.93 GB, Process: 127.96 TB/127.99 TB
Total Downloaded: 33.25 MB (this session: 32.60 MB)
Total Uploaded: 5.11 MB (this session: 4.89 MB)
after 2hour..and runing one torrent
the torrent only have 0/113(seeding)
but connect is come up 1307...why
Up Time: 2:44:27
Overall Tasks: Total: 1 / Running: 1
TCP Connections: Established: 1307 [MAX:Unlimited] / Half-Open: 35 [MAX:200]
Overall Download Rate: 80 kB/s [MAX:Unlimited] Max Connection Limits: 9999 per task
Overall Upload Rate: 17261 kB/s [MAX:Unlimited] LT Seeding: 0 kB/s [MAX:Unlimited] All BT Upload Slots: 110
Memory Usage: Working Set: 16.19 GB, Commit Size: 16.18 GB
Free Memory: Physical: 38.78 GB/63.93 GB (Min to keep: 50 MB), Virtual: 36.90 GB/63.93 GB, Process: 127.95 TB/127.99 TB
Disk Cache Size: 16 GB (Min: 4096 MB, Max: 16384 MB)
Disk Read Statistics: Request: 14485650 (freq: 1013.2/s), Actual Disk Read: 62557 (freq: 6.0/s), Hit Ratio: 99.5%
Total Downloaded: 93.44 GB (this session: 917.81 MB)
Total Uploaded: 360.44 GB (this session: 237.74 GB)
after few minute is come up 1647 (seeding @ 0/107)
![](/monthly_2018_04/5ae31c1034031_QQ20180427204753.png.7054afa9fcd21427d1e3aab328e6b15f.png)
Update…
/monthly_2018_04/1.png.f2214eb786be0f50bdfda02a031a871d.png" data-fileid="2897" rel="">![](/monthly_2018_04/1.thumb.png.2b5c610533e1afcf749d5a87d5ecabf1.png)
the peer numbers of 0/xxx means o seeds and xxx peers. If a peer disconnects and reconnects they are counted again as bitcomet doesn’t count only actice peers, but the important number is the seeds, with zero seeds it will never download.
