Ok! I don’t know what I did wrong this morning (other than my brain was too tired), but I finally got it right. Now, I am confused about the step that I’m supposed to take, where I “enter the static IP I want to forward to” (which in the tutorial states that it is 192.168.2., and in the space, enter the last digit of my IP address). I didn’t see this step in the portforwarding steps. There steps were, as follows: I changed the UPnP (in BitComet Advanced Settings), set my “Listen Port” #, I entered my Internal IP address (Default IP) in the address bar (as their steps stated), clicked on firewall button, clicked firewall settings, (my PC name was already entered in the “select computer” box), clicked “Add new user-defined application”, in “Application name” box I entered “BitComet”, entered the port range # that I had selected to be my “Listen port” in BitComet “Options”, clicked “Add definition”, clicked “back” button, selected BitComet in the “Applications” list, clicked “Add” (to add BitComet to the “Hosted Applications” box), and then I clicked “Done”. I then downloaded, installed, and ran PFPortChecker, I entered the port # to check & selected TCP, clicked “Check me”, and it wasn’t open. Therefore, I shut down all firewall protection Windows Firewall & AVG Firewall), tried it again, and (SUCCESS) it was open! Now, I need to know if I missed something somewhere, where was I supposed to enter the 192.168.2.? Also, I have selected BitComet as an exception for Windows Firewall, and I haven’t figured out how to make an exception on AVG Firewall. I have the free version, if that makes a difference. As long as AVG is off, the port is open. In my AVG, I don’t understand how to add BitComet & PFPortChecker. It keeps stating that the file doesn’t exist. How do I resolve this issue (I can’t be surfing the web without protection)?
My additional info (just to show that I am not as childish as Deeder):
IP address: 198.168.1.64
Subnet: 255.255.255.0
Default Gateway IP: 192.168.1.254
BitComet Settings: Global max dl-unlimited
Global max upload- 32
By the way, I love how you genuis, free-giving people put him in his place! You guys are GREAT, and I thank you for your time & patience! Sorry, if this post is too explanatory, I just wanted to show what I did in detail. Many thanks, again!
