Hola, veo que han quitado la version 0.70 de bitcomet y ahora supuestamente la 0.77 es la ultima version estable. Pero hace una semana atras, me lo instale y no andaba ni para atras ni para adelante. Tambien veo que hay muchos post que dicen lo mismo, que la version 0.77 anda mal. ¿Acaso le han corregido algo para que lo considere estable ahora?
Recien segui los pasos del tutorial “Guía para Redirigir el Puerto y Establecer IP Estática” Me quede con dudas, el modem que tengo es de CastleNet modelo CXC150 y en las opciones no sale este modelo, solo sale “AS800” y “CBW511”. ¿Que hago? ¿Elijo cualquiera de los dos?
Por ultimo, eso de tener que loguearse dentro de bitcomet 0.77 ¿para que sirve? Porque en la version 0.70 no hay esa cosa.
Bueno, espero que me respondan y de antemano muchas gracias.
Saludos
Fernando
Hello, I see that BitComet v. 0.70 has been removed and, now v.0.77 is supposedly the latest stable version. About one week ago, however, I installed it, but it didn’t work ‘any way you looked at it’. I also see that there are a lot of posts that say the same thing: that v.0.77 doesn’t work well. Have they corrected something to make me consider it stable now?
As soon as I followed the steps in the “How to Set up Portforwarding & Static IP” Guide, I was left with doubts. The modem that I have is a CastleNet, model CXC150 and, in the options, it doesn’t show that model - only “AS800” and “CBW511”. What should I do? Should I just choose any which one of the two?
Lastly, the part about having to log in, within BitComet v.0.77 - what is the purpose of this? - because in v.0.70 there is no such thing.
Well, I hope that you reply and, I thank you very much, in advance.
Regards,
Fernando
