testing 0.73
I upgrade to 0.73 and when a download finish i choose “move to”, then a popup ask me to “continue or cancel” (yes or not), i choose cancel (no) and it moves anyways :frowning:
Moreover i have two downloads now and bitcomet is using 291.492kb of memory, i think this is so much (i never seen 0.70 eating this memory even with more downloads) as well as sometimes bitcomet goes to 99% of cpu usage for some seconds (freezing a little my computer :angry: ). Seems that some core rewrite is needed :wink:
I found some bugs in spanish translation too.
these problems are a result of version .71 having serious problems, so replacement versions are being rushed a bit to try and improve it.
You will also notice that version .70 is STILL listed as current STABLE version.
suspect
v0.73 very good,
(02 Oct)
but now face problem oredi
Hey, im only trying to found bugs to help developers :rolleyes: so this is not a complaint.
I can confirm a bug when finish a download, bitcomet (default installation) opens a explorer in “Program Files\BitComet\codecs”
I see no reason for that.
Cheers,
most Anti Leech Tracker give an error with Bitcomet 0.71 0.72 and 0.73:
Torrent not registered with this tracker
After some hours running i get this error message… and bitcomet crash.
/post-7965-1159456739.gif" rel=“”>
The announce times are way too high (up to 1 hour (or even more?)). Trackers “forget” the client that way. So other clients do not see you until the next announce is done.
I found some annoying things too.. The layout moves back to default when its minimized.. and it crashes sometimes for me.. and every time there is hashchecking it brings up the \program files\bitcomet folder.. very strange
