Too many connections !!!
Hi! When I start on my client, i have too many connections (i see it in KWF).
/post-12470-1161336544.jpg" rel=“”>
The reason KFW is showing so many connections is probably because of the DHT Network.
Disable the DHT Network in Bitcomet’s options and then restart Bitcomet and you will see way less connections.
The DHT Network doesnt actually make any 2-way connections. They technically are connectionless packets but most firewalls will still keep track of the transmission as if it were a real “connection”.
Is this causing a problem for your computer or for your download speeds?
It shouldnt really cause any problems unless your firewall is trying to do an nslookup on all those “connections”
if it is resolving all those addresses then this will cause a problem and you should figure out how to turn this option off in your firewall
Yeah Yeah !!! 10x a lot !!! And waz’happen if I turn off DHT Network?
Nothing will happen really.
The DHT Network just helps you find peers when there is no working tracker for a torrent
I only enable the DHT Network if there is a torrent that I really really want and there is no working tracker for it or there are no seeds.
I have problems with files with a lot of peers, like this one:
With other files i can reach up to 80kB/s, but those files have less peers.
Also, with files with a large number of peers, the webpages became very slow.
I already tried to turn off DHT Network, but i keep getting a lot of peers
After you turn off the DHT Network you have to restart Bitcomet for it to work
Also you should lower the number of connections that Bitcomet makes
There is really no need to connect to 200 peers which it appears that you’re doing
In the settings change the max connections per task to something like 50
Also based on that upload speed you’re showing you should change the Global Max Upload Slots to about 6
And make sure that Max Half-open tcp connections is set at 8
All of this is explained in our Settings Guide (link in my sig)
I did what u said, and now i downloading another torrent at 50 kB/s, with a lot of peers connected. So i think this torrent : could have some problems, beacuse i can’t get more than 20kB/s
You could try http://www.lvllord.de/
TCP Limit Patcher
I did what u said, and now i downloading another torrent at 50 kB/s, with a lot of peers connected. So i think this torrent could have some problems, beacuse i can’t get more than 20kB/s
Look at the totals of seeds vs peers. Thats a new & popular .torrent with only a few seeds so yes it will be slow.
TCP half-open connection Limit Patcher
That has nothing to do with this.
