Torrent history not working
I have just reformated my PC and tried to save my torrent history list but it doesnt show up in bitcomet. I backed up my archive folder (containing thousands on bitcomet files named with random numbers and letters) which was located in AppData>Roaming>Bitcomet and put it on the same place after reformating. Dont know what went wrong
I solved it myself by dragging all files at one into bitcomet, then put a soda can on the escape key. After a few min all torrents were back in torrent history :slight_smile:
That’s not the only thing you need to back up. You also need the torrents subfolder and all of the .xml files, which are where your configuration data and your tasklist are stored.
