when i click on that, it locks up and says bitcomet has encountered an error and needs to close.
any ideas guys?
i really dont want to have to switch back to utorrent because it basically sucked but i dont know what to do.
thanks in advance.
-aaron
any ideas guys?
thanks in advance.
-aaron
Its possibe this is not related to bit comet.
I suggest you try removing and reinstalling.
I would also stop all other applications and observe if it is working.
ps. If problem persists I would post a lot more info regarding your system and programs you are using.
ive included the errorlog.txt below.
B i t C o m e t c a u s e d a n A c c e s s V i o l a t i o n ( 0 x c 0 0 0 0 0 0 5 )
i n m o d u l e B i t C o m e t . e x e a t 0 0 1 b : 0 0 4 5 7 9 7 5 .
E x c e p t i o n h a n d l e r c a l l e d i n E x c e p t i o n A t t a c h e r . c p p - A f x W i n M a i n .
E r r o r o c c u r r e d a t 8 / 9 / 2 0 0 6 1 8 : 0 3 : 0 4 .
D : \ P r o g r a m F i l e s \ B i t C o m e t \ B i t C o m e t . e x e , r u n b y A a r o n .
O p e r a t i n g s y s t e m : W i n d o w s X P ( 5 . 1 . 2 6 0 0 ) .
1 p r o c e s s o r ( s ) , t y p e 5 8 6 .
8 8 % m e m o r y i n u s e .
2 4 7 M B y t e s p h y s i c a l m e m o r y .
2 8 M B y t e s p h y s i c a l m e m o r y f r e e .
8 3 4 M B y t e s p a g i n g f i l e .
4 4 6 M B y t e s p a g i n g f i l e f r e e .
2 0 4 8 M B y t e s u s e r a d d r e s s s p a c e .
1 9 5 6 M B y t e s u s e r a d d r e s s s p a c e f r e e .
R e a d f r o m l o c a t i o n 0 0 0 0 0 0 0 0 c a u s e d a n a c c e s s v i o l a t i o n .
C o n t e x t :
E D I : 0 x 0 0 f 4 1 2 5 8 E S I : 0 x 0 0 0 0 0 0 0 0 E A X : 0 x 0 0 0 0 0 0 0 0
E B X : 0 x 0 0 0 0 0 0 0 0 E C X : 0 x 0 0 0 0 0 0 0 0 E D X : 0 x 0 0 0 0 0 0 0 1
E I P : 0 x 0 0 4 5 7 9 7 5 E B P : 0 x 0 0 0 0 0 0 1 0 S e g C s : 0 x 0 0 0 0 0 0 1 b
E F l a g s : 0 x 0 0 0 1 0 2 4 6 E S P : 0 x 0 0 1 2 f 1 4 0 S e g S s : 0 x 0 0 0 0 0 0 2 3
B y t e s a t C S : E I P :
8 a 0 1 8 3 c 1 0 1 3 a c 3 7 5 f 7 2 b c a 5 1 5 6 8 d 4 c 2 4
S t a c k :
0 x 0 0 1 2 f 1 4 0 : 0 5 8 1 f 4 0 5 0 0 0 0 0 0 0 0 0 0 f 3 8 1 8 8 0 0 1 2 f 4 9 8 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 1 5 0 : 0 0 f 2 e f f 0 7 7 4 2 0 4 9 e 0 0 1 9 0 4 8 0 0 0 f 7 6 9 0 0 . . . . . . B w . . . . . i . .
0 x 0 0 1 2 f 1 6 0 : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 1 7 0 : 0 0 0 0 0 0 0 f 0 0 f 3 8 1 f 0 0 0 f 2 9 a 5 8 0 0 0 0 0 0 0 0 . . . . . . . . X . . . . . . .
0 x 0 0 1 2 f 1 8 0 : 7 7 4 2 0 4 9 e 0 0 f 7 6 9 0 0 0 0 0 0 0 0 0 f 0 0 0 0 0 0 0 0 . . B w . i . . . . . . . . . .
0 x 0 0 1 2 f 1 9 0 : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 f 0 0 6 3 1 0 9 4 . . . . . . . . . . . . . . c .
0 x 0 0 1 2 f 1 a 0 : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 1 b 0 : 0 0 0 0 0 0 0 0 0 0 f 2 9 9 1 8 0 0 f 2 9 9 b 8 0 0 5 6 d 7 2 8 . . . . . . . . . . . . ( . V .
0 x 0 0 1 2 f 1 c 0 : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 1 d 0 : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 f 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 1 e 0 : 0 0 1 7 c 9 0 0 0 0 0 0 0 0 0 0 0 0 3 3 c e b 8 0 0 1 9 0 4 0 0 . . . . . . . . . . 3 . . . . .
0 x 0 0 1 2 f 1 f 0 : 0 0 1 2 f 2 0 8 5 a d 7 3 4 e 0 0 0 1 9 0 4 8 0 0 0 0 0 0 0 0 0 . . . . . 4 . Z . . . . . . . .
0 x 0 0 1 2 f 2 0 0 : 0 0 0 0 0 0 0 f 0 0 0 0 0 0 0 4 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 2 1 0 : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 f 4 f 2 5 8 5 a d 7 6 8 7 7 . . . . . . . . X . . . w h . Z
0 x 0 0 1 2 f 2 2 0 : 0 0 1 9 0 4 8 0 0 0 0 0 1 8 5 7 0 0 0 0 0 0 3 c 0 0 0 0 0 0 3 f . . . . W . . . < . . . ? . . .
0 x 0 0 1 2 f 2 3 0 : 0 0 5 6 b 6 a e 0 0 f 7 d 4 a 8 0 0 1 9 0 4 8 0 0 0 0 0 0 0 4 7 . . V . . . . . . . . . G . . .
0 x 0 0 1 2 f 2 4 0 : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 6 8 0 0 0 0 0 0 6 f 7 f f f f f f f . . . . h . . . o . . . . . . .
0 x 0 0 1 2 f 2 5 0 : 0 0 0 0 0 0 0 0 0 0 1 2 f 2 d c 0 0 6 1 3 d c 5 f f f f f f f f . . . . . . . . . = a . . . . .
0 x 0 0 1 2 f 2 6 0 : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 7 0 0 0 0 0 0 0 f 0 0 f 3 0 0 0 0 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 2 7 0 : 0 0 6 4 1 0 a 8 0 0 1 2 f 2 7 c 0 0 f 3 8 1 8 8 0 0 0 0 0 0 0 0 . . d . | . . . . . . . . . . .
0 x 0 0 1 2 f 2 8 0 : 0 0 0 0 0 0 0 7 0 0 5 6 e 0 0 0 0 0 f 2 0 0 0 0 0 0 0 0 0 0 0 0 . . . . . . V . . . . . . . . .
0 x 0 0 1 2 f 2 9 0 : 0 0 5 6 e 0 5 0 0 5 8 1 f 7 a 9 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 7 P . V . . . . . . . . . . . . .
0 x 0 0 1 2 f 2 a 0 : 0 0 0 0 0 0 0 0 0 5 8 1 f 4 1 5 0 0 0 0 0 0 0 0 0 0 1 2 f 4 6 4 . . . . . . . . . . . . d . . .
0 x 0 0 1 2 f 2 b 0 : 0 0 6 2 0 7 5 d 0 0 0 0 0 0 0 1 0 0 4 7 4 2 1 7 0 0 f 3 8 1 e 8 ] . b . . . . . . B G . . . . .
0 x 0 0 1 2 f 2 c 0 : 0 5 8 1 f 7 8 5 0 0 0 0 0 0 b 2 0 0 f 3 9 4 a 8 0 0 1 2 f 4 9 8 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 2 d 0 : 0 0 f 2 e f f 0 0 0 1 7 c 9 e 8 0 0 f 3 8 1 8 8 0 0 0 0 0 0 0 0 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 2 e 0 : 0 0 6 1 3 c a 5 0 0 1 2 f 3 7 0 0 0 5 6 e 0 5 3 0 0 5 6 e 0 8 7 . < a . p . . . S . V . . . V .
0 x 0 0 1 2 f 2 f 0 : 0 0 0 0 0 0 0 0 0 0 1 9 0 4 8 0 0 0 0 0 0 0 0 f 0 0 0 0 0 0 0 0 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 3 0 0 : 0 0 0 0 0 0 0 0 0 0 5 6 e 0 5 3 0 0 1 2 f 3 3 4 7 7 d 4 8 7 3 4 . . . . S . V . 4 . . . 4 . . w
0 x 0 0 1 2 f 3 1 0 : 0 0 1 9 0 4 8 0 0 0 0 0 0 0 0 f 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 3 2 0 : 0 0 5 6 e 0 5 3 d c b a a b c d 0 0 0 0 0 0 0 0 0 0 1 2 f 3 7 0 S . V . . . . . . . . . p . . .
0 x 0 0 1 2 f 3 3 0 : 0 0 5 6 e 0 5 3 0 0 1 2 f 3 9 c 7 7 d 4 8 b d 9 7 f f d d 0 0 0 S . V . . . . . . . . w . . . .
0 x 0 0 1 2 f 3 4 0 : 0 0 1 2 f 3 9 c 7 7 d 4 8 8 5 a 0 0 1 2 f 3 5 c 7 7 d 4 8 8 2 a . . . . Z . . w \ . . . * . . w
0 x 0 0 1 2 f 3 5 0 : 0 0 1 7 d b 0 8 0 0 1 9 0 4 8 0 0 0 f 3 8 1 8 8 0 0 0 0 0 0 1 4 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 3 6 0 : 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 1 7 d b 0 8 0 0 0 0 0 0 0 0 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 3 7 0 : 0 0 0 0 0 0 0 0 0 0 1 2 f 3 8 4 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 3 8 0 : 0 0 0 0 0 0 0 0 0 0 1 2 f 3 5 0 0 0 0 0 0 0 c 6 0 0 1 2 f 3 e 0 . . . . P . . . . . . . . . . .
0 x 0 0 1 2 f 3 9 0 : 7 7 d 7 0 4 6 7 7 7 d 4 8 8 3 0 f f f f f f f f 7 7 d 4 8 8 2 a g . . w 0 . . w . . . . * . . w
0 x 0 0 1 2 f 3 a 0 : 7 7 d 4 b 4 c 0 0 0 1 7 d b 0 8 0 0 5 6 e 0 5 3 0 0 1 9 0 4 8 0 . . . w . . . . S . V . . . . .
0 x 0 0 1 2 f 3 b 0 : 0 0 0 0 0 0 0 f 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 b b 4 4 7 4 . . . . . . . . . . . . t D . .
0 x 0 0 1 2 f 3 c 0 : 7 7 d 4 b 4 c b 0 0 0 0 0 0 0 2 0 0 f 4 d 5 c 0 0 0. . .
0 x 0 0 1 2 f 7 3 0 : 0 0 1 2 f 8 b c 7 7 4 1 d 6 2 9 0 0 1 b 8 d f 8 0 0 1 2 f 8 8 4 . . . . ) . A w . . . . . . . .
0 x 0 0 1 2 f 7 4 0 : 0 0 0 1 0 0 0 0 0 0 1 b 8 d f 8 7 7 d 4 8 4 f c 7 7 d 4 8 5 a 4 . . . . . . . . . . . w . . . w
0 x 0 0 1 2 f 7 5 0 : 0 1 0 d 0 4 7 c 0 0 1 2 f 8 a c 0 0 0 0 0 0 0 0 0 0 1 2 f 7 9 4 | . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 7 6 0 : 7 7 d 4 9 4 8 8 0 0 b d d d 1 8 0 0 0 0 0 0 0 0 7 7 d 4 9 4 9 1 . . . w . . . . . . . . . . . w
0 x 0 0 1 2 f 7 7 0 : 0 0 1 2 f 8 a c 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 2 f 7 7 0 . . . . . . . . . . . . p . . .
0 x 0 0 1 2 f 7 8 0 : 0 0 0 0 0 0 0 0 0 0 1 2 f 8 c 8 7 7 d 7 0 4 6 7 7 7 d 4 9 4 9 8 . . . . . . . . g . . w . . . w
0 x 0 0 1 2 f 7 9 0 : f f f f f f f f 7 7 d 4 9 4 9 1 7 7 4 3 d b 3 3 0 1 0 d 0 4 7 c . . . . . . . w 3 . C w | . . .
0 x 0 0 1 2 f 7 a 0 : 0 0 0 0 0 0 0 0 0 0 1 2 f 8 4 4 7 7 4 4 4 3 6 9 0 1 0 d 0 4 7 c . . . . D . . . i C D w | . . .
0 x 0 0 1 2 f 7 b 0 : 0 0 1 2 f 8 a c 7 7 4 4 4 3 3 b 7 7 4 4 5 a c f 7 7 d 4 9 4 9 1 . . . . ; C D w . Z D w . . . w
0 x 0 0 1 2 f 7 c 0 : 7 7 d 4 8 4 f c 7 7 d 4 8 5 a 4 0 0 6 5 0 3 2 4 0 0 1 2 f 9 2 4 . . . w . . . w $ . e . $ . . .
0 x 0 0 1 2 f 7 d 0 : 0 0 0 0 0 0 0 0 0 0 1 2 f 8 0 c 7 7 d 4 9 4 8 8 0 0 b 8 8 7 6 8 . . . . . . . . . . . w h . . .
0 x 0 0 1 2 f 7 e 0 : 0 0 0 0 0 0 0 0 7 7 d 4 9 4 9 1 0 0 1 2 f 9 2 4 0 0 0 0 0 0 0 0 . . . . . . . w $ . . . . . . .
0 x 0 0 1 2 f 7 f 0 : 0 0 0 0 0 0 0 0 0 0 1 2 f 7 e 8 0 1 0 d 0 4 7 c 0 0 1 2 f 9 4 0 . . . . . . . . | . . . @ . . .
0 x 0 0 1 2 f 8 0 0 : 7 7 d 7 0 4 6 7 7 7 d 4 9 4 9 8 f f f f f f f f 7 7 d 4 9 4 9 1 g . . w . . . w . . . . . . . w
0 x 0 0 1 2 f 8 1 0 : 7 7 4 3 d b 3 3 0 0 6 5 0 3 2 4 0 0 0 0 0 0 0 0 0 0 1 2 f 8 b c 3 . C w $ . e . . . . . . . . .
0 x 0 0 1 2 f 8 2 0 : 7 7 4 4 4 3 6 9 0 0 6 5 0 3 2 4 0 0 1 2 f 9 2 4 7 7 4 4 4 3 3 b i C D w $ . e . $ . . . ; C D w
0 x 0 0 1 2 f 8 3 0 : 7 7 4 4 5 a c f 7 7 d 4 9 4 8 8 0 0 b d d d 1 8 0 0 0 0 0 0 0 0 . Z D w . . . w . . . . . . . .
0 x 0 0 1 2 f 8 4 0 : 0 0 0 0 d f 5 c 0 0 1 2 f 8 7 0 7 7 d 4 8 7 3 4 0 1 0 d 0 4 7 c \ . . . p . . . 4 . . w | . . .
0 x 0 0 1 2 f 8 5 0 : 0 0 0 0 0 0 8 7 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 7 7 4 4 4 3 3 b . . . . . . . . . . . . ; C D w
0 x 0 0 1 2 f 8 6 0 : d c b a a b c d 0 0 0 0 0 0 0 0 0 0 1 2 f 8 a c 0 0 0 0 0 0 0 0 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 8 7 0 : 0 0 6 5 0 3 2 4 0 0 0 0 0 0 0 0 7 f f d d 0 0 0 0 0 1 2 f 8 d 8 $ . e . . . . . . . . . . . . .
0 x 0 0 1 2 f 8 8 0 : 7 7 d 4 8 8 5 a 0 0 1 2 f 8 9 8 7 7 d 4 8 8 2 a 0 0 0 0 0 0 8 7 Z . . w . . . . * . . w . . . .
0 x 0 0 1 2 f 8 9 0 : 7 7 4 4 4 3 3 b 7 7 d 4 8 4 f c 7 7 d 4 8 5 a 4 7 7 4 4 4 3 3 b ; C D w . . . w . . . w ; C D w
0 x 0 0 1 2 f 8 a 0 : 0 0 1 2 f 9 f 8 0 0 0 0 0 0 0 0 0 0 1 2 f 8 e 0 7 7 d 4 9 4 8 8 . . . . . . . . . . . . . . . w
0 x 0 0 1 2 f 8 b 0 : 0 0 b 8 8 7 6 8 0 0 0 0 0 0 0 0 0 0 0 0 d f 5 c 0 0 1 2 f 8 e 8 h . . . . . . . \ . . . . . . .
0 x 0 0 1 2 f 8 c 0 : 7 7 d 4 8 7 3 4 0 0 6 5 0 3 2 4 0 0 0 0 0 0 8 7 0 0 0 0 0 0 0 0 4 . . w $ . e . . . . . . . . .
0 x 0 0 1 2 f 8 d 0 : 0 0 0 0 0 0 0 0 7 7 4 4 4 3 3 b d c b a a b c d 0 0 0 0 0 0 0 0 . . . . ; C D w . . . . . . . .
0 x 0 0 1 2 f 8 e 0 : 0 0 1 2 f 9 2 4 7 7 4 4 4 3 3 b 0 0 1 2 f 9 5 0 7 7 d 4 8 b d 9 $ . . . ; C D w P . . . . . . w
0 x 0 0 1 2 f 8 f 0 : 7 f f d d 0 0 0 0 0 1 2 f 9 5 0 7 7 d 4 8 8 5 a 0 0 1 2 f 9 1 0 . . . . P . . . Z . . w . . . .
0 x 0 0 1 2 f 9 0 0 : 7 7 d 4 8 8 2 a 0 0 0 0 0 0 8 7 7 7 4 4 4 3 3 b 0 0 0 0 0 1 1 1 * . . w . . . . ; C D w . . . .
0 x 0 0 1 2 f 9 1 0 : 0 0 0 0 0 0 1 4 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 9 2 0 : 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 9 3 0 : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 8 1 0 0 1 2 f 9 0 4 0 0 0 0 0 1 1 1 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 9 4 0 : 0 0 1 2 f a 5 c 7 7 d 7 0 4 6 7 7 7 d 4 8 8 3 0 f f f f f f f f \ . . . g . . w 0 . . w . . . .
0 x 0 0 1 2 f 9 5 0 : 7 7 d 4 8 8 2 a 7 7 d 4 c 6 3 f 0 0 1 7 d b 0 8 7 7 4 4 4 3 3 b * . . w ? . . w . . . . ; C D w
0 x 0 0 1 2 f 9 6 0 : 0 0 6 5 0 3 2 4 0 0 0 0 0 0 8 7 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 $ . e . . . . . . . . . . . . .
0 x 0 0 1 2 f 9 7 0 : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 7 7 d 4 8 4 f c 7 7 d 4 8 5 a 4 . . . . . . . . . . . w . . . w
0 x 0 0 1 2 f 9 8 0 : 0 0 6 5 0 3 2 4 0 0 1 2 f a d c 0 0 1 2 f b a 0 0 0 1 2 f 9 c 4 $ . e . . . . . . . . . . . . .
0 x 0 0 1 2 f 9 9 0 : 7 7 d 4 9 4 8 8 0 0 b 8 8 7 6 8 0 0 0 0 0 0 0 0 7 7 d 4 9 4 9 1 . . . w h . . . . . . . . . . w
0 x 0 0 1 2 f 9 a 0 : 0 0 1 2 f a d c 0 0 1 2 f b a 0 0 0 0 0 0 0 0 0 0 0 1 2 f 9 a 0 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f 9 b 0 : 0 0 0 0 0 0 0 0 0 0 1 2 f a f 8 7 7 d 7 0 4 6 7 7 7 d 4 9 4 9 8 . . . . . . . . g . . w . . . w
0 x 0 0 1 2 f 9 c 0 : 0 0 0 0 0 4 1 7 0 0 1 2 f b a 0 0 0 1 c 6 3 1 8 0 0 1 2 f a 7 4 . . . . . . . . . c . . t . . .
0 x 0 0 1 2 f 9 d 0 : 7 7 4 4 5 1 c 2 0 0 1 c 6 3 1 8 0 0 1 c 6 a c 0 0 0 1 2 f b a 0 . Q D w . c . . . j . . . . . .
0 x 0 0 1 2 f 9 e 0 : 0 0 1 2 f a d c 7 7 4 4 4 3 3 b 7 7 4 4 5 a c f 7 7 4 4 4 3 3 b . . . . ; C D w . Z D w ; C D w
0 x 0 0 1 2 f 9 f 0 : 7 7 4 4 5 a c f 0 0 f 3 0 2 b c 0 0 1 7 c 9 e 8 0 0 f 3 0 2 b c . Z D w . . . . . . . . . . . .
0 x 0 0 1 2 f a 0 0 : 0 0 1 2 f a 6 8 0 0 5 6 e 0 0 0 7 7 d 4 8 4 f c 7 7 d 4 8 5 a 4 h . . . . . V . . . . w . . . w
0 x 0 0 1 2 f a 1 0 : 0 0 6 5 0 3 2 4 0 0 1 2 f b 6 c 0 0 1 2 f c 3 0 0 0 1 2 f a 5 4 $ . e . l . . . 0 . . . T . . .
0 x 0 0 1 2 f a 2 0 : 7 7 d 4 9 4 8 8 0 0 b 8 8 7 6 8 0 0 0 0 0 0 0 0 7 7 d 4 9 4 9 1 . . . w h . . . . . . . . . . w
0 x 0 0 1 2 f a 3 0 : 0 0 1 2 f b 6 c 0 0 1 2 f c 3 0 0 0 0 0 0 0 0 0 0 0 1 2 f a 3 0 l . . . 0 . . . . . . . 0 . . .
0 x 0 0 1 2 f a 4 0 : 0 0 0 0 0 0 0 0 0 0 1 2 f b 8 8 7 7 d 7 0 4 6 7 7 7 d 4 9 4 9 8 . . . . . . . . g . . w . . . w
0 x 0 0 1 2 f a 5 0 : 0 0 0 0 0 4 1 7 0 0 1 2 f c 3 0 0 0 1 c 6 3 1 8 0 0 1 2 f b 0 4 . . . . 0 . . . . c . . . . . .
0 x 0 0 1 2 f a 6 0 : 7 7 4 4 5 1 c 2 0 0 1 c 6 3 1 8 0 0 1 c 6 a c 0 0 0 1 2 f c 3 0 . Q D w . c . . . j . . 0 . . .
0 x 0 0 1 2 f a 7 0 : 0 0 1 2 f b 6 c 7 7 4 4 4 3 3 b 7 7 4 4 5 a c f 7 7 4 4 4 3 3 b l . . . ; C D w . Z D w ; C D w
0 x 0 0 1 2 f a 8 0 : 7 7 4 4 5 a c f 0 0 0 0 0 0 0 2 0 0 1 2 f b a 0 7 7 4 4 4 3 3 b . Z D w . . . . . . . . ; C D w
0 x 0 0 1 2 f a 9 0 : d c b a a 0 0 1 7 c a 2 0 . . . . l . . . . . . . . .
0 x 0 0 1 2 f e 0 0 : 0 0 1 7 c a 1 8 0 0 b b 1 1 d 8 0 0 0 0 0 0 1 4 0 0 0 0 0 0 0 1 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f e 1 0 : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 . . . . . . . . . . . . . . . .
0 x 0 0 1 2 f e 2 0 : 0 0 7 d 3 f 5 c 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 \ ? } . . . . . . . . . . . . .
0 x 0 0 1 2 f e 3 0 : 0 0 1 2 f d f c 0 0 1 2 e d 6 4 0 0 1 2 f e 9 8 7 7 d 7 0 4 6 7 . . . . d . . . . . . . g . . w
0 x 0 0 1 2 f e 4 0 : 7 7 d 4 8 8 3 0 0 0 0 0 0 0 0 0 0 0 1 2 f e a 8 7 7 d 4 8 9 c d 0 . . w . . . . . . . . . . . w
0 x 0 0 1 2 f e 5 0 : 0 0 0 0 0 0 0 0 0 0 5 f 0 4 5 0 0 0 3 6 0 3 3 2 0 0 0 0 0 5 0 9 . . . . P . _ . 2 . 6 . . . . .
0 x 0 0 1 2 f e 6 0 : 0 0 0 0 0 4 6 c 0 0 0 0 0 0 2 0 0 0 b b 1 1 e c 0 0 0 0 0 0 0 1 l . . . . . . . . . . . . . .
0 x 0 0 1 2 f e 7 0 : 0 0 1 7 c 9 e 8 0 0 1 7 c a 1 8 0 0 0 0 0 0 0 1 0 0 4 4 a d e c . . . . . . . . . . . . . . D .
0 x 0 0 1 2 f e 8 0 : 0 0 1 7 c a 1 8 0 0 1 7 c a 1 8 0 0 0 0 0 4 6 c 0 0 0 0 0 0 0 0 . . . . . . . . l . . . . . . .
0 x 0 0 1 2 f e 9 0 : 0 0 1 2 f e 7 0 0 0 1 2 e d 6 4 0 0 1 2 f f 0 8 7 7 d 7 0 4 6 7 p . . . d . . . . . . . g . . w
0 x 0 0 1 2 f e a 0 : 7 7 d 4 8 9 f 0 f f f f f f f f 0 0 1 2 f e b 8 7 7 d 4 8 a 1 0 . . . w . . . . . . . . . . . w
0 x 0 0 1 2 f e b 0 : 0 0 1 7 c a 1 8 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 5 7 b 8 a f . . . . . . . . . . . . . . W .
0 x 0 0 1 2 f e c 0 : 0 0 1 7 c a 1 8 0 0 1 7 c a 1 8 0 0 7 d 9 9 2 8 0 0 5 7 b 5 6 0 . . . . . . . . ( . } . ` . W .
0 x 0 0 1 2 f e d 0 : 7 c 8 0 a c d 3 0 0 0 0 0 0 0 1 0 0 1 2 f f 1 8 0 0 0 0 0 0 0 0 . . . | . . . . . . . . . . . .
0 x 0 0 1 2 f e e 0 : 0 0 0 0 0 0 0 0 0 0 1 7 c 9 e 8 0 0 4 5 c 5 0 f 0 5 8 1 f a 5 9 . . . . . . . . . . E . Y . . .
0 x 0 0 1 2 f e f 0 : 0 0 7 d 9 9 2 8 0 0 7 d 9 9 2 8 f f f f f f f f 0 0 7 d 9 9 2 8 ( . } . ( . } . . . . . ( . } .
0 x 0 0 1 2
dont think it’d be much good to you but there it is anyways.
i did a re-install and torrentz still seemed to be the ONLY ONE having problems when clicking on it.
whats the website i can go to instead?
im running avast AV and zone alarm firewall.
thats all that was running when i had re-installed this software.
below are my computer specs.
XP Home, 2002, service pack 2 — Intel® Celeron™ CPU — 1066MHz — 1.06 GHz, 248 MB of RAM
need anything else, just let me know.
i’ve also downloaded this software from your site.
