Tracker Problem
unable to connect to tracker…
http://btfans.322.org:8080/announce : cant connect to tracker
whats wrong? what happened? how do i correct it? please HELP!
i never had this problem, have been using bitcomet for 2 years+, portforwarding done & firewall removed.
connection : 11Mbps
using bitcomet 7.0
The tracker is probably down. Try looking up the error number from the error message.
firewall removed.
Are you using the net without a firewall? That’s bad, you should have atleast one firewall running. Even the XP SP-2 firewall will do the job. You just have to keep an up to date antivirus with it.
