Transfer torrents from mutorrent to BitComet 1.3.2
Hello,
I have many downloaded by mutorrent torrents. I have torrent file and file with content.
I changed my client from mutorrent to BitComet anfd would like to seed already downloaded torrents by BitComet.
I tried open new torrent -add torrent from torrent file and note the way to already exist files with content.
Then to avoid the repeat download I stop the torrent and start Check hash.
I thought that in this case the BitComet see that the files with content already downloaded and start to seed it.
But BitComet after check hash doesn’t see that files alreaddy exist (downloaded) and informed me that the progress of download is 0% and start to download files one time more.
Please explain what I do incorrect and how I can seed the files.
/monthly_05_2012/post-97971-0-69396600-1337193161.png" rel=“”>
/monthly_05_2012/post-97971-0-48091700-1337193190.png" rel=“”>
/monthly_05_2012/post-97971-0-69224300-1337193226.png" rel=“”>
My head hurts.
What???
If you really pointed BC to the folder where the torrent files are, you should see a warning message and after you perform hash-check you should get 100% progress. Double-check that you pointed it to the right folder.
You need to point BC to the folder which holds the folder with your torrent files NOT inside the torrent folder.
