trouble downloading
:huh: Hello. I’m very new to this entire torrent thing,still having problems understanding all of it. i’m getting better than i was. anyway,when i download movies,only some of them work,barely any as a matter of fact.
i read somewhere that i need a folder called video_ts???
i would also like to burn them onto blank dvd’s. i have nero 7 ultra as the burning software. i’m just not too sure of the entire proccess. can someone please help me out here. thanks in advance.
p.s. if you need any more info,just ask.
The so call “some of them work” work in what?
manage to download? manage to play the files or what?
please be more specific~ :mellow:
Raw dvd video files would be in a folder like this, however full dvd video torrents are not very common.
Some full DVD torrents are in disc image files, such as .iso, .nrg, .mds/.mdf, .bin/.cue and others.
You will however find full dvd torrents are rare, very large, and download very slowly, or never finish.
Most movies these days are .avi files encoded with divx/xvid. These will not play on most dvd players (only specially made units designed to play these.
If you want to download movies ready to burn to disc, then I suggest you try downloading KVCD movies. They are highly compressed video designed to burn to CDr disc NOT dvdr, but most dvd players will play them.
Some info on kvcd…
Why kvcd???
A commercial dvd is approx 8,000mb in size (far to big to download quickly), and needs to be “shrunk down” to fit a dvdr disc (4.38gb) Still to big to download quickly.
KVCD is encoded to be burnt onto a standard cdr disc, and when played on a dvd player provides almost as good video quality as the orignal dvd, and with an approx size of 800mb.
You might wonder how kvcd can encode a movie at 1/10 the size of a dvd and still look good.
The answer is complex, but suffice it to say that kvcd is set to display direct to your tv screen so no resolution is lost in providing pixals that cannot be displayed. It also uses complex software to create a varible bit rate, this way it improves quality of video for parts of the film that require it, and lowers bit rate for parts that don’t.
Creating kvcd is an art, and not all kvcd downloads are equal.
Tus kvcds have become known as the best world wide, and we have a strong following, and all our torrents are well seeded.
Also, since you have nero seven ultra, I posted a guide for converting most file types to dvd with nerovision.
you can find it in our guides section. However, this will take from 1 to 10 hours to do one disc, and a movie download of 0.7gb will require the full 4.38gb of your DVDr disc when converted (unless you lower quality to fit more on.
Kvcd uses CDr discs because they are much better at playing highly compressed video. Also, I can download a couple dozen kvcd movies in the time it takes for some full DVD movies to download. Plus, if I like a movie enough to want the full dvd, I just buy it.
ps. Check the links on my siggy if you want to try kvcd (the dvdrips are the best quality)
