Trouble por forwarding with Bellsouth DSL.
I have a Westell WireSpeed DSL Modem. Model # B90-220030-4
When I go to launchmodem to enable port forwarding, I get this error every time I try large port numbers.
"Your Base Host Port and your End Port in your range exceeds 65535.
The ports I’m trying to use are 49152 for Host port and global port range from 49152 - 63950. Do any of you know what may cause this problem and how I can be able ot have a high port range open without having that error.
Thank you.
I don’t know why you think you need so many ports open, but it sounds like you’re just mis-entering the information.
