TS maVen kvcd
I have downloaded a couple of DVDrip TUS kvcd and can now burn to CD. I recently downloaded a TS maVen kvcd but can not burn this to CD using the same technique, i.e. Nero. Any suggestions?
When I first investigated BitComet I found an area detailing the types of files that can be downloaded i.e DVDrip, Screening etc. I can not find this information a second time. Can anyone tell me where to locate it?
Thanks in advance.
Arent TUS releases always image files that you can burn directly.
If your file is a .iso or any other image type .bin/.cue, etc then you should give imgburn a try
Other than that Im sure The UnUsual Suspect could help you
