UDP not working & TCP/UDP listen port closed show open?
I Posted Pictures To Make This Crystal Clear.
Hi I’m Experienced User Also I’m Not New To BitComet It Is My Favourite Client But There Is Something Strange About It Udp Ports Never Work The Indicator Always Show Yellow Not Green But When I Switch To Statistics Tab It Show Opened?
also when i set a udp port for remote download or as a listen port it never work?
why that?
My TCP Port 10004 Is Opened & It Is Working Great But Bitcomet Show That 10004 udp protocol is opened too although it is closed?
why that?
All My Softwares Are Updated B.T.W Except BitComet.
All My Ports Are Configured Correclty.
To Ensure That My Ports Are Working I Use PF Port Checker.
Other Info:
BT Client:BitComet v1.35 x64
OS:Windows 7 Ultimate SP1 x64
Protection Suit:Norton 360 v20.3.0.36
Connection:ADSL 512kpps
1 Router 1 desktop Pc
Router Type:TD-8816 v6.0
Sorry For Caps & Bad English It Is A Bad Habit I Know.
This is highly confusing.
The remote control port is a different thing as compared to the listen port.
It uses TCP not UDP.
As for the listen port, the ports the fact that the ports appear both open if indeed you still have a yellow light, that is odd, I’ve never seen that behavior.
You’ll have to back it up with some more synchronized sshots (where you actually show the status lights), in order for this to be considered a bug report, I guess.
opening bitcomet says listen port is blocked,how do i open it— tanbits
Please do NOT jump into the middle of someone else’s topic with unrelated requests.
Start your own in the proper section and with all of the minimum information.
i faced this problem before if you can remember it is been 4 years now since last time i made the same thread here
how can I back it up?
I already did you have the pictures above
sorry but i give up i guess this is your part to check out the problem and report back a solution afterall this is your client and you know it better than anyone else :wink:
TheWheelOfFate2010,
Bitcomet just like any other bittorrent client requires an open connection to the internet. If you elect to install routers or other devices that can block the connection, then you need to have them properly configured. Problems with listening ports being open should be addressed to the network administrator who runs the LAN, if you don’t know who that is, then it’s probably you. A network admin would then turn to the router manufacturer to get technical help with that product. There are thousands of different routers and we can’t possibly know how they all work.
You are talking to bitcomet users who volunteer their time to help you. If we can demonstrate a problem with the client we will pass it on to development to work on, but we need to be able to reproduce the problem and in this case it’s probably an issue with router settings and not related to bitcomet at all.
Also, where bitcomet reports that the udp port was opened in firewall or router, in this case it only opened the port in your firewall as you’ll also see it says upnp device not found, so it cannot access your router so you’ll need to open the ports yourself or troubleshoot why the router is being blocked and cannot be accessed by bitcomet in order to use upnp.
my all settings are ok im sure of it because other clients such as utorrent are working just fine
besides i found something strange and maybe this is the issue
BitComet Always Try To Detect TCP Ports And Not UDP Ports here i made some tests
Here is what i see when bitcomet starts:
then bitcomet target tcp port and try to detect it wheather it was open or not:
bitcomet report it is blocked:
Now you see above that the indicator show yellow although my udp port is open and working
I hope this helps to identify the issue
If you used the same settings for utorrent and bitcomet, it won’t work, they each need their own unique rules with unique ports.
You need an open TCP port, the problem is probably with your router or firewall settings, or the port could already be used by another app.
I Know all of this but my port is not busy with other app im sure of it
i just tell my UDP port 10003 work with all applications “except bitcomet” now this is strange isn’t it?
and you didn’t asnwered my question if my UDP is open as bitcomet say here
then why the indicator didn’t turned into green?
The indicator won’t turn green unless it’s able to receive an unexpected remote TCP connection from BitComet’s servers, a test signal to determine if you’re able to listen for peers.
According to your screenshot BitComet was able to add NAT port mapping to your router and it appears to be working with udp, but that isn’t conclusive, and it appears there is a problem with tcp, but that too isn’t conclusive and even if it was successful in opening your router for both protocols, any firewalls or security software/IP filtering software used could still block the connections.
If you allow it, bitcomet can control the windows firewall and certain routers, but you could have an infinite number of things blocking your incoming connections, all of which have to be open for the port to work. I think you are incorrectly assuming that if bitcomet reports being able to open the port in your router, that it is also opened in all of your other devices/software, but this is not the case. The indicator at the bottom that reports your port is blocked is a functional test and won’t read “green” unless all obstacles are clear.
I’ve found that many members experiencing problems like you are have multiple routers in series. In many cases they don’t even realize that a device they assumed was a modem was actually also a router. The most effective way to trouble shoot this is to remove the router/s and see if you can get an open port, this will help to eliminate possible causes as to where the connection is being blocked.
I’d also recommend using a port in the 50,000 to 60,000 range, these aren’t reserved for any applications and will have less chance of being in conflict. You can also use an independent method of testing the port, I use http://canyouseeme.org it’s a free open port testing utility, just assure bitcomet is running so that the port will be registered and test it on that website, it will tell you if you’re able to receive remotely initiated connections.
If you are able to remove the router (as a test) and the port is open, that would confirm the problem is in your router in which case it would probably be easiest to disable uPnP port mapping and open the port manually for both TCP and UDP connections.
i have 2 ports are opened 10003 UDP and 10004 TCP
Bitcomet Work Good With 10004 Tcp But Not Working With 10003 UDP
And For utorrent It is working great with 10003 UDP also it work great with 10004 TCP
sorry for wasting your time maybe i should stick to utorrent for now
but what i don’t like it about utorrent it is slower than bitcomet
As I mentioned in a prior post, you cannot use the same post for utorrent and bitcomet. Each app needs it’s own port number and you can only use ONE port number for both TCP and UDP connections.
Assign a unique port to bitcomet, select any random number between 50,000 and 60,000 and make a portforwarding rule in our router so that port is opened for both TCP and UDP connections for bitcomet. Some routers will allow you to do this with one rule, and some will require two rules, both with the same port number.
What I Meant Is I Already Know That i cannot use the same port for 2 different software
but still i wonder why utorrent can use 1 udp port and the indicator turn into green while bitcomet can’t do that?
I’ve been trying to understand what you’ve been doing to attempt to open your ports and it’s very difficult to follow your posts. It looks like you are trying to open two different ports, one for udp and one for tcp… if so, that is probably one of your problems. It’s also possible that you don’t even have a problem at all, have you tested your listening port at canyouseeme.org as I suggested?
Also are you using any IP filtering software like peerguardian/peerblock or protowall/blocklist manager?
canyouseeme.org can’t reach me but i use PF Port Checker And It Is working great
yes I use PeerBlock But this doesn’t Affect my download/upload Speed not even the ports i use
First question… but not the first time I’ve asked this so I’ll make it bold…
Why are you testing two different port numbers???
BitComet only uses one port for incoming connections.
If you use peerblock with some of the common block lists your computer will not allow bitcomet to make connections to do things like find you LTseed connections and test your port status. This is why information like this should have been in your very first post. If you want to use PeerBlock you’ll need to make an allow list for the IP addresses used by bitcomet. This info is listed in the FAQs at wiki.bitcomet.com.
ps. if canyouseeme.org cannot connect, then your port is not open
I Already told you my ports are working 100% with any other software
besides i have tried to use bitcomet without peerblock it still acting the same way
so any ideas to make bitcomet indicator turn into green on this port 10003 UDP Only? Like Utorrent?
I’m trying to help you but I don’t think you are understanding what I am telling you. If you prefer to have someone else help, I’ll ignore this topic any any other member is more than welcome to try to explain this to you.
If you do want my help then the first thing you need to do is stop trying to use two different ports, you use the same port for TCP and UDP. Go to
Options>Connection>Listen port
What port number is listed?
Test that port at canyouseeme.org while bitcomet is running, if it cannot see you on that port, then the connection is blocked. It doesn’t matter what your PF port checker says, that isn’t testing if your port is open to the internet but the canyouseeme.org website is.
If your port is blocked, the most likely cause is in your router so you’ll need to make a rule to direct the incoming connections on that port go to the correct computer using both TCP and UDP protocols.
If you use a different port number, it won’t work.
Well… I can already see that your feathers are starting to… not become ruffled but, rather…outright curl!!! (I can’t blame you) :wink:
Why don’t you just choose the port for him (kluelos used to do that, lol)? Just tell him to “set TCP to use 54321 and UDP to use 54321”.. Why?..'Cuz you said so, that’s why. :smiley:
agreed with EAGLE. check setting in router & allow firewall setting for incoming/outgoing for bitcomet.
Norton 360 is one of the best for internet security but it wont let the TCP open especially Norton 360 with patched/cracked.
got to setting in norton 360 allow/excluded bitcomet from protocol filtering. norton still can detect suspicious data during downloading..
but some of the malware can make a handshake & can pass thru if you used default setting for norton.
used port no from 40000 till 60000 you’ll get the best speed & more peers.
and agreed with Cassie too, refer previous topics. you’ll get the answer
