as you can see utorrent has no problems getting peers, while bitcomet is stuck
i don’t see how this can be related to ip because utorrent at the very same time has no problems
that happened again
magnet:?xt=urn:btih:SWEL2D526SDAMEKPY4UPEAAWTBLUNOUR&dn=s03e10&tr=udp%3A%2F%2Ftracker.openbittorrent.com%3A80&tr=udp%3A%2F%2Ftracker.publicbt.com%3A80&tr=udp%3A%2F%2Ftracker.istole.it%3A6969&tr=udp%3A%2F%2Ftracker.ccc.de%3A80&tr=udp%3A%2F%2Fopen.demonii.com%3A1337&xl=1849172912
I tested the task you reported and all the trackers work for me except the ccc.de which probably no longer exists.
The rest of the trackers connected instantly and if they are working with one client but not with another, your problem is probably with a firewall or router that’s blocking the connection.
i don’t know what to tell you guys
i tested on another network today and still get UDP tracker no response while utorrent is working fine
i get some peers via DHT but the speed is nowhere near to utorrent (if i manage to get any peers at all)
i repeat, i don’t have any firewalls and the router is the same for bitcomet and utorrent
Post another magnet link, I’ll test it and see if it works for me. If we can reproduce a problem, it will get sent to development for them to look at.
well it has nothing to do with this or that magnet link
basically every torrent from piratebay has only udp trackers and bitcomet is not able to get peers from them while utorrent works fine at the same time on the same computer
bitcomet sends a connection attempt to each tracker, this has to pass through any firewalls and routers you have (there is a very good reason why we ask you to provide details about what you are using). If the tracker receives the connection they will reply and that connection has to make it through your router and firewall. You cannot assume that if one client works and the other doesn’t that it’s the client at fault, it could be that you have the same port used for both clients but only one can use the port, or the router settings could be correct for one client and not for the other.
Bitcomet requires an open internet connection to work and although we do attempt to help users setup their hardware to allow bitcomet, but in your case I don’t even recall if you’ve posted a list of the hardware you are using or if you tried bypassing your router as I suggested… this would tell us where to look if it works without the router connected. Also I recall you saying is suddenly started working at one point… could that have been a time when uTorrent wasn’t running? if you want two clients to work concurrently you need to have separate settings that don’t conflict.
