I’m using version 0.63, i try to upgrade to any newer version it keep on giving me message like: cannot find C:\Document&setting\XXX\XXX\12346[1].torrent or invalid menu handle. After i re-install back the 0.63 everything back to normal again… Can anyone help ? :unsure: :unsure: :unsure:
What version/s did you try to install?
0.70 and 0.73
Regarding your attempt to install version .70.
When did you get the error message? during install? or when trying to run a torrent?
Meantime, you need to verify that the directory in question does actually exist, and that you have read/write permissions in it.
after installation, when program launch…
