Upgrade to 0.70 Problem
HP Laptop:
Windows XP-Pro (SP-2)
Beta IE 7 (7.0.5700.6) Release Candidate 1
2.2 GHz AMD Athlon™64 Processor
1024MB System Memory
ATI RADEON® XPRESS 200M IGP W/128MB Memory
Integrated 10/100BASE-T Ethernet LAN
I have been using BitComet about 3 - 4 months without problems. I recently upgraded from 0.67 to 0.70 and now MOST of the Wtorrent links (70%) display in either the Japanese or Chinese character set. Obviously that renders these links useless as I can’t read the item details.
Did I do something wrong during the upgrade installation? OR is there a way to correct this in some obscure BitComet profile? I have searched the forums and the FAQ’s to no avail.
Thanks in advance for anyone’s help with this.
C.
We are aware of this issue, and are working on correcting it.
I suggest you use your browser for searching until it is resolved.
