i would like to know what the relationship between the upload and download rate is. I guess my question relates to two things:
if you try to change the rates in preferences, you get a message saying "your download rate effects your upload rate or vice-versa, and
why on lots of occasions during the downloading process, is the upload rate significantly higher than the down rate? Shouldn’t this be the other way around?
using BitComet 0.79; XP; wireless broadband.
If this is posted in the wrong section, then prior apologies.
