using wlan router and hasnt connectivity
hi,
i just setup a wlan connectiion with a us robotics router, and dont know why i cannot upload with bitcomet.
tracker has no connectivity with my pc.
so please if you have some idea whats wrong, help me
thanks
If you can’t connect to the tracker, then you probably have a software firewall blocking BitComet’s outbound connections. You’ll have to find it and create a rule allowing BC access to the net.
