V 1.37 BitComet [20131231] has been released
Thanks TUUS… :smiley:
i need help
help me
(Mod. Edit: Giant duplicate images deleted, as they have nothing to do at all with this thread.)
i need help
We’d be glad to help, but not if we have to struggle to get information out of you, that could take weeks to solve a problem that could be diagnosed in a few minutes.
When will the a new version be uploaded?
Its been more than 2 years now.
No, it’s been about 1 year.
1.37 is a very stable version and thus far there hasn’t been anything compelling enough to trigger an update.
Hi,
What ever changes I make in the UI is being saved only till the system is ON.
The next time you switch ON/restart the system none of the changes are being shown. Everything is collapsed. Again I need to do it.
Eg. Hiding VIP, Comments.
  Width of column in peers, statistics.
  Even the bar adjustment which is separating from Tasks and Bookmarks.
Highly irritating.
Request you to fix these issues in the next update.
Make sure you are actually shutting down bitcomet not just minimizing it. If it’s not fully shut down the settings won’t be saved and it will revert to default. Clicking the X button doesn’t shut it down by default.
i have no search box next to the search engens.How do i find torrents?
It works fine for me, but you don’t need bitcomet’s help to find torrents, you can go to any torrent site with any browser.
is it possible turn off hash check after finishing download? in options all of it are disabled.. but it still make check after finishing…
If you disable the option to use .bc! file extension bitcomet won’t have to rename the files when complete and there won’t be any delay. This is probably what you’re witnessing rather than a full hash check
not helpped to me. it is not problem on 2-5gb torrents.. but when it is 50+gb torrent it takes time.. all hash checks are disabled. i using 64bit version. also there is one thing.. when i press stop on checking and start again. it thinks that all is ok and start uploading.
http://1drv.ms/1MnUVZq ← screen of checking
±äÐνð¸Õ1.Transformers.2007.BD1080P.X264.AAC.Mandarin&english.CHS-ENG.Mp4Ba.torrent±äÐνð¸Õ1.Transformers.2007.BD720P.X264.AAC.Mandarin&english.CHS-ENG.Mp4Ba.torrent
The latest version of BitComet has just been released, you’re all welcomed to download it from Here.
Changelog
		v1.37 2013.12.31
GUI Improved: add download speed/progress graph in task summary pane
GUI Improved: add download size in total, upload size in total, torrent create time in task list, hidden by default
GUI Improved: display new finished tasks in bold
GUI Improved: display proxy server connection errors in task log
GUI Improved: after hash checking, mark the banned and removed files in piece map as empty
GUI Improved: improve the operation of open file, open folder and invoke anti-virus software, avoid UI not response
GUI Improved: add new language: Kurdish
GUI Bugfix: fix the bug of missing file extension name when start download by Magnet URI
GUI Bugfix: fix the bug of not keeping selection state when switch between task list and torrent exchange list
GUI Bugfix: install package supports Windows 8.1
Core Improve: improve Firefox extension to support multiple Firefox versions
Core Bugfix: fix the bug in Firefox extension that unable to start BitComet from Save As dialog
Core Bugfix: fix the bug of the save folder of HTTP/FTP file is not set to the desired one from remote download webpage
Please feel free to leave your comments and feedback here.
Thank you for your support,
The BitComet Team
hello hi
