kiat24
August 17, 2006, 10:02am
1
hi guys, need some help from those who know.
i can’t have more than 8 files downloading in Ver0.7, if i start the 9th file, it will stop all files from loading. it’s ok for v0.59 i used last time, u can have like 20 over files to load. any1 have the same problem like mine? pls help. thx for ur reply.
the more files you have trying to download, the more they are choking on the connection.
i think it is healthier for you and everyone else if you do not try to load over 20 files
kiat24
August 17, 2006, 11:43am
3
but, how come tat in v0.59, i can load 20+ files @ 1 go?
This is the main reason bit comet runs slow is when people run so many files at once.
You are becomming a bad peer, and only harming the download speed of thousands of peers you are connected to.
If you have less then 1mb/s upload rate, you should run only one torrent at a time, or two at the very most.
This will help you, and REALLY help everyone you are connected to.
We all hate to have a seeder or peer that gives us less then 1kB/s
Please consider what I say, and help to make bit torrent work faster for everyone
Sincerely,
