For versions .76 and above, make a new topic in bit comet client support. Besure to include as much info as possible and fully describe your problem.
Although these new versions are still considered “less then stable”, we do have many members using them without issue.
Regarding version .71-.75, Please either install .70, or if you want to use the new client, then get the latest version.
Our two latest versions .71 and .72 have some serious issues (we are sorry).
If you still feel you must post a question regarding these versions, do so here. I however will not be responding to these questions (personally).
Thank you for taking the time to read this,
Sincerely,
Message to all Users from BitComet Team:
We deeply apologise for all the latest ‘unstable’ releases - 0.71, 0.72, 0.73. Aimee has notified RnySmile of this serious issue, and rectifications are now underway.
recently installed v.7.0, but this problem occured some time before (using 6.0):
any torrents I download now become inactive unless I’m physically at the computer doing something (!?)
i.e., when I ‘wake’ the computer up, torrents then try to ‘reconnect’, but then still the speed is much slower than b4.
a couple of months ago this didnt happen…I installed 7.0 thinking it would fix the problem but no change
This topic is NOT for requesting help with any STABLE versions. Please make a new topic regarding any version Prior to .71
Although your question has been answered, your system is going into standby mode, you will need to disable that for download to continue. You can use (monitor power down), but not cpu or hard drive.
ps. Until I receive instructions from admin, I will not (personally) be supporting versions .71 and .72, but you are welcome to post your questions here, or reply to them.
Your telling me. What the h*** is up with .73?
I am on a 512 connection, so I set my download limit to half my bandwidth which is 26 KB/S, so I can comfortably surf at the same time, Bitcomet 7.3 then goes nuts and maxes out to 52 KB/S!
Launching new downloads causes it to crash, running a video preview causes it to crash, why would BitComet release the severly unstable version, this is not open source, FIX IT!!!
:blink: hello. i just upgraded to .73 and now see chinese writings in the main info box?!
at the bottom of the screen i c a greyed-out bitcomet icon next to the text not logged in. how do i log in? next to that the DHT green light is a go but it’s not connected to any nodes?!?! how can i tell if my torrent is a private one andnot allowing DHT. i was running 68 then 70 and DHT would only connect now and then. i’m running utorrent as well and its’ DHT is connected and has like 300 nodes. :blink:
am i actually connected to DHT ? is this an error in bitcomet and why won’t 68/70 connect to DHT at all but still d/l? thanx for any replies
i think i double posted this thread…sorry :blink:
download last stabble reliase bitcomet 0.70 and thats it.New versions have some bugs(0.71,0.72,0.73)
Yeah BitComet 0.73 initially wants to install in Chinese for me too. Even when I select English, and it installs in English, it still wants me to download the Chinese language pack. That’s kind of funny.
0.73 also crashes on me in a similar manner as every build between 0.64’n 0.69 and 0.71’n 0.72. I sent in the crash reports hope you got 'em and I hope they help.
I don’t drink coffee but I’ll keep my cool anyway. BitComet is my favorite client, crashes and all. And 0.70 is stable as a rock for me. Now if the >16’s would just go away… .
I have a question about BitComet. I had a older version of BitComet, I think it was .68. I uninstall .68. I downloaded the newer version .73. (plus other versions to..)
With myn old version I had no problem to start myn download torrents..
Now what I try it dont work now :S
I got the version .73 (Nothing else (versions) get open)
I download a torrent form a site, but the torrent wont start on bitcomet…
Who can help me please?
(I am sorry for my poor English and I hope i am in right section of the forum for this problem)
Thank you all for your patience & co-operation!
BitComet Team.
Added this onto Don’s Message
admin i have one question :rolleyes: and bitcomet 0.74 or later would be fine? :unsure:
Actually I would like to ask how to make the “would you like the new features of the bitcomet 0.73 by visting www.bitcomet.com” pop-up to keep comming up everytime I open bitcomet, and also on my listen port it keeps setting itself back to 6882 everytime I open bitcomet, and 50% of the time when the port is on 6882 my files that I’m downloading via bittorrent gets corrupted, so I have to set it to “64450” port everytime and I find it quite annoying.
Don’t tell me to download 0.70 stable version because I tried all the versions and they all have the same problem.
This sounds like a problem with something on your computer not allowing you to save the changes you have made.
I suggest you log on as admin (if not already), and make the port change, and any other settings. Also, if you have any security, or privacy software running that requires users to log in, this may stop you from making changes to system files.
If you are running on a beta version of windows vista, I would suggest you install bit comet to an “unprotected” portion of the harddrive, as vista seems to be extremely limited to what can be viewed, or edited in the program files folder.
