VIP acceleration problem
I get “Network error. Please retry later” when I try to activate VIP acceleration. Is this a common problem that will be solved if I try later? Or must I finetune configuration?
I’m using BitComet 1.31.
Internet via 3G modem.
Windows XP.
best regards
/Otto
Running now, answer to the first question seems to be “yes”.
/Otto
Glad it’s working for you. I haven’t seen this error, but it’s probably a connection error that is displayed for any number of reasons.
I’ve got the same problem…
don’t know how to add an image
Just click the “Image” button, and enter the url of the external site (such as Flickr or Photobucket) where you have already uploaded the image. You can’t host or upload images to the forum server itself.
(Edit:Actually, I’m told that you can upload images here, but I’ve never gotten it to work. This method definitely works.)
Actually you can kluelos, unless you’ve found a bug since the last update. Just click “more reply options” and you can select attachments.
please i have a proplem with the vip acceleration
it shows to me :
network error
how i can solve it
