Hello!
I'm not commenting on the installation, the problem is when running the program. The antivirus deletes the executable ......
greetings/monthly_2022_01/725045525_Capturadepantalla(285).png.03503db973b13645a205c82f3bdae005.png" data-fileid="3418" data-fileext="png" rel="">.thumb.png.98629115fde0bb87c340b1cfecf85c13.png)
Avast has been reporting Win32 (and Win64) Malware for several years now. It’s NOT a virus - Avast is detecting a false positive in several apps, including malwarebytes. Google for malware.gen avast and you will see the number of reports and almost all are reporting a ‘false positive’
I use Adaware A/v with daily updates and I've only ever known a virus report to occur on initial installation (on earlier versions of BC) due to the installation app. I've never had one on the program itself (and I scan daily)
Ok Rhubard!
I already take into account when I install or update BitComet to pause the AV; until today it had not happened to me that when running the program the antivirus jumped like crazy.
I close the thread
Thanks
It’s definitely a false positive from Avast. There have been reports for some years now of Avast mis-identifying files and applying a ‘heuristic’ label
