VPN Connection Management - Intergration
Hi guys,
I am wanting to know if there is or will possibly be any integration for BitComet & Open VPN’s?
As no connection is 100% up, drop outs can occure leaving my connection unprotected while still torrenting. Ive found this numerous times of late.
I have heard that Vuze is the 1 main client that intergrates a VPN connection service, it stops downloading if the VPN connection is disconnected or interupted.
http://torguard.net/blog/vpn-disconnect-solution/
There are a couple software options which do this, but it makes more sense for it to be in the torrent client rather than using 1 software monitor 2 others & control bitcomet.
http://torrentfreak.com/how-to-shut-down-utorrent-automatically-when-your-vpn-disconnects-130707/
I dont want to change clients, I quite like BitComet, and rather not use another software - if I dont have to… whats the go in this please??
thanks in advance
Using VPN is a reliable service for bypassing restrictions, encrypting your browsing on public Wi-Fi Hotspots and increasing your connection speed to get through all blocked websites without any blocking. Download your suitable version and get your free trial immediately http://www.proxybreaking.com/en/download/
