was downloading but stopped
I have bought the 100GB VIP and had downloaded some files and received the full 100% file but I have started some more files and it has downloading at 0% but have anywhere from 10% to 63% of the files downloaded but just seemed to lock up I reset my router to see if that would help but it didn’t (as of yet). Is there anything a member has to do it downloading stops at 0% ???
In order for vip (or regular) downloading to complete the torrent/s must be seeded. If there are no seeds present, then the task isn’t likely to complete. If you enabled vip on a task that cannot complete, you will have the option to cancel the vip task and your account will be credited for that bandwidth.
