My Bitcomet program is working just fine, but i cant get the window here do go small enough, so that i can reach the “OK” button. What should i do
The best way to have more windows on your monitor is to increase its resolution (check “Properties” of your “Display” by right-clicking on your Desktop) - e.g. 800x600 → 1024x768; another way is to use smaller fonts. The simplest workaround is to move the window somewhat upper (press “Alt”, “Left”, “Down”, select "Move"and use direction keys) or to use keyboard+mouse for navigating instead of just mouse (use “Tab” to cycle within window, “Enter” to press focused button, “Esc” for “Cancel”, “Alt-Tab” for switching between open windows). Check “Hotkeys” section of your Windows’ Help for it.
