Where are my PEERS??????
So for years I have been using Bitcomet and with no issues. Lately when I download a torrent I don’t get any peers or seeds on the summary tab unless I connect to a VPN.
Does anyone know why this is happening? Is there a setting in Bitcomet that I have to change to open the download up to peers or is this something to do with my ISP?
Tx in advance.
As you arten’t running a beta version (in fact no-one is running a beta), this topic was moved.
As for your problem - you may find that you have a port issue - that the only open port is the one that is set to the VPN. It could be your ISP blocxking certain ports - in which case the 'cure' is to try something well out of the normal range, coupled with a fixed Intranet IP
