Using x64 v1.36
All I want to do is set my upload speed to less than 10 kB/s while I’m downloading a file. If I put in 5 into global upload, it automatically defaults to 10. I’ve searched google to no avail.
Was using uTorrent and was able to put 1 into that setting and then allow unlimited when file has finished downloading. This gave me the best download speed and all I want to do is be able to try this speed in BC.
Is it possible?
TIA
Running a torrent with less than 10kB/s upload is going to be harmful to everyone including yourself. If your getting faster downloads with less upload then you have something seriously wrong. You should cap your upload at about 80% of your max tested upload speed, this will allow for the most upload and the more you upload, the more you will download, this principle is built into the protocol. Unless you’re on a horribly slow connection you should never set your upload as low as 10kB/s.
