Quoted from the wiki of BitComet:
[http://wiki.bitcomet.com/add_port_mapping_in_nat_router](http://wiki.bitcomet.com/add_port_mapping_in_nat_router)
Quote
To get the best speeds, BitComet needs an open listening port, just as
most other P2P applications do.
http://wiki.bitcomet.com/bitcomet_status_bar
Quote
An yellow light means BitComet successfully requested the probe, but
did not detect it at your listen port. This indicates that the port is
blocked by one or more firewalls. Your client can therefore reach
other clients but other clients can not initiate contact with your
client.
If your listen port is blocked you can still transfer files with
BitComet, but your transfer speed probably won't be very high.
[http://wiki.bitcomet.com/bitcomet_options](http://wiki.bitcomet.com/bitcomet_options)
Quote
No listening Mode: will greatly slow down your upload/download rate.
Not recommended. (Exceptions are those who are situated behind routers
or firewalls which they cannot access and configure. For them, this
setting will provide the means to still be able to download even
though at much lower speeds).
E.g. I can't not configure the outermost firewall, so the listening port used by BitComet is blocked, thus I can only be a client not a host. But how would it ** greatly slow down** the download speed? I can still connect to all the other peers who can be a host as a client.
Is it merely because I would lose those client peer connections if I can be a host?
I am a programmer and interested in this problem. A technical explanation is ok and appreciated. Because now my ISP does not allow me to configure the outermost firewall, so if this affects the speed hugely, I would consider to choose another ISP who can give me a "real public ip"( I can configure the outermost firewall ).
Did you set up port forwarding in the router? To do this successfully you will need to give the target computer a fixed intranet IP number(on the lines of 192.168.0.### if your routerhas a numberin that series). You will then have to add port forwarding (I use a block of ports) in the router itself and the port in bitcomet set to one of those.
Hmmm. That’s not what I asked. I just want to know, if my BitComet’s listening port is blocked, in which I can’t be a server. How badly my download/upload speed will decrease ? Because in the Wiki of BitComet, it mentions that it will hugely impact the download speed. I just want to know how and why in a technical perspective. But I’ think I’ve found the answer somewhere else. So thank you for replying :).
The simple answeris that if you block the app from hearing, it doesn’t receive responses from trackers or any downloading so it simply doesn’t know what speed the otherperson is receiving at, so it slows things down.
In a nutrshell, if a person is hearing impaired, you have to shout and even then you can't be sure if they actually heard and understood
Without an open listening port you will not receive any peer initiated requests. The only way you can connect to a peer is if you initiate the connection and most peers in a swarm already have the connections they need.
As new peers enter the Swarm they will try to connect with others except they cannot reach you. You will not know they exist until you receive a Tracker update and by then they may have all the peers they need. If you cannot receive incoming connections your performance is going to be horrible on most torrents. I highly recommend you get a better internet connection and mobile broadband is never a good option when using peer-to-peer downloading.
Fiber optic is usually the best option
I am having the yellow light listen port blocked issue. I currently run WIndows 10pro and have norton security suite. I have created a new rule in Norton but I still cannot open the listen port. Any ideas? I am not a techie person so any help would be great.
check that port forwarding is set up from your router - it’s best to use a fixed IP on the computer before allocating ports
