Will not connect ??
Can anyone shed any light please..
working on windows 7 . not had a problem then all of a sudden nothing…
i’m getting a grey light ’ your listening port statues unknown ’ message when i hover over it…
never seen this before and have no idea how to fix it ,
i also can not sign in
It seems like something is blocking BitComet servers on your side.. Have you installed any IP blockers (like peerguardian, etc) or any other security software lately?
You can test the listen port at canyouseeme.org.
Nope not installed anything new and no peerguardian installed !! ill look at that site you said
just ran it on port 7049 and it returned thiscomment from the site you said to try
Error: I could not see your service on port (7049)
Reason: Connection timed ou
That’s the common response when you have a firewall blocking the port. (It does not respond to activity, just makes like a hole in cyberspace, nothing to see here, move along.) So the connection times out with no response.
It’s pretty evident that something changed. You have to find out what that was.
We can try to help but we’ll need the information that was requested in the sticky topic titled “PLEASE READ BEFORE POSTING”.
