window 98
hi , anyone can help me here?
i am using window 98 , which have no language support unless i use NJ star .
So when i want to download chinese or japanese using Bitcomet, it is unable to create folder as the character all appear ???.
anyone can help on this?
thanks a lot
Try to download the language pack for win98. But you’ll probably find that difficult since at the beginning of this month MS discontinued 98 & ME. But it never hurts to try.
You should consider upgradeing to win2k or XP Pro.
