wireless connections
how should my d/l rate and u/l rate be set to with wireless…clearly im a beginner to this so i have my settings set to no limit…i need help!
The bandwidth of your wireless connection is far, far higher than your internet connection’s bandwidth. No matter how much you might or might not increase the wireless speed, you’ll still be bottlenecked by your internet connection. So you don’t need to be concerned about the wireless end.
uh if you are reffering to your bc upload limits i wouldnt set both to no limit.
if you are uploading alot and use all your upload bandwidth you download bandwidth will really drop.
