Ok so I the yellow listening port is blocked and I’ve got the yellow light and I can’t seem to fix it!! I’ve been trying for days now and have ran out of things to try. Could someone please help me.
I have followed all the steps on this to no avail:
http://wiki.bitcomet.com/add_port_mapping_in_nat_router
When I was at step 4 for Bitcomet UPnP Auto Port Mapping for the Windows 7 bit, when I right clicked on my modem/router instead of having two tabs “general” and “network device” I only have 1 tab which is “network device”. so I can’t click the settings button as it says to in the instructions.
Other than that I followed all the instructions and didn’t seem to have any problems.
I used this program:
http://www.softpedia.com/get/System/System-Miscellaneous/UPnP-Test.shtml
and this is the result:
TEST 1 - Operating System Support - PASSED
TEST 2 - SSDP Service Running Check - FAILED
TEST 3 - SSDP Service Automatic Check - FAILED
TEST 4 - UPnPHost Service Running Check - FAILED
TEST 5 - UPnPHost Service Automatic Check - FAILED
TEST 6 - UPnP Framework Firewall Exception Check - PASSED
TEST 7 - Adapter #0 - 192.168.1.2 - FAILED
TEST 8 - Get External IP Address - FAILED
But in services.msc it says SSDP and UPnP are both started and on automatic.
My router/modem details are:
Huawei
HG630
Bitcomet Statistics:
Up Time: 0:31:03
Overall Tasks: Total: 14 / Running: 0
TCP Connections: Established: 0 [MAX:Unlimited] / Half-Open: 0 [MAX:200]
LAN IP: 192.168.1.2
WAN IP: 14.203.200.1
Listen Port of TCP: 12264 (Blocked by Firewall/Router)
Listen Port of UDP: 12264 (Opened in Firewall/Router)
Windows Firewall: Failed
UPnP NAT port mapping: Failed
Disk Boost Service: Running
Overall Download Rate: 0 kB/s [MAX:8000] Max Connection Limits: 50 per task
Overall Upload Rate: 0 kB/s [MAX:8000] LT Seeding: 0 kB/s [MAX:7995] All BT Upload Slots: 0
Memory Usage: Working Set: 99.99 MB, Commit Size: 69.65 MB
Free Memory: Phys: 5.12 GB (Min to keep: 50 MB), Pagefile: 12.75 GB, Virtual: 8,191 GB
Disk Cache Size: 0 B (Min: 6 MB, Max: 50 MB)
Disk Read Statistics: Request: 0 (freq: 0.0/s), Actual Disk Read: 0 (freq: 0.0/s), Hit Ratio: 0.0%
Disk Write Statistics: Request: 0 (freq: 0.0/s), Actual Disk Write: 0 (freq: 0.0/s), Hit Ratio: 0.0%
Total Downloaded: 623.45 GB (this session: 5.33 KB)
Total Uploaded: 847.18 GB (this session: 1.98 KB)
I am on windows 7 using zonealarm firewall.
What am I doing wrong?
Thanks
