yellow light
Up Time: 2:53:35
Overall Tasks: Total:17 / Running: 17
TCP Connections: Established: 29 [MAX:Unlimited] / Half-Open: 50 [MAX:200]
LAN IP: 192.168.1.2
WAN IP: 175.156.230.210
Listen Port of TCP: 65535 (Blocked by Firewall/Router)
Listen Port of UDP: 65535 (Opened in Firewall/Router)
Windows Firewall: Added [TCP added, UDP added]
UPnP NAT port mapping: Failed [Huawei Technologies Co., Ltd. (http://www.huawei.com/)] (HG256 model)
Disk Boost Service: Running
Overall Download Rate: 5 kB/s [MAX:Unlimited] Max Connection Limits: 50 per task
Overall Upload Rate: 2 kB/s [MAX:10] LT Seeding: 0 kB/s [MAX:3] All BT Upload Slots: 4
Free Phys Mem: 356.30 MB (Min to keep: 50 MB)
Memory Usage: Working Set: 163.13 MB, Commit Size: 203.69 MB
Disk Cache Size: 6.50 MB (Min: 6 MB, Max: 50 MB)
Disk Read Statistics: Request: 368 (freq: 0.2/s), Actual Disk Read: 93 (freq: 0.0/s), Hit Ratio: 74.7%
Disk Write Statistics: Request: 999 (freq: 0.1/s), Actual Disk Write: 174 (freq: 0.1/s), Hit Ratio: 82.5%
Total Downloaded: 3.82 GB (this session: 30.82 MB)
Total Uploaded: 581.47 MB (this session: 15.37 MB)
can send email to me.. gsk98159@yahoo.com.sg
i am using asus notebook with window 7 system. i got a new huawei gateway hg256. i already follow all the step but still yellow light…
It looks like the forwarding rule in your router is set to forward only the UDP protocol. It needs to forward TCP traffic as well.
On some routers, this means adding another rule, one for each protocol. Some routers allow you to specifically choose “TCP/UDP”. Some routers allow you to choose “BOTH”, and still others give you the choice, “ALL”.
I went to Network sharing & saw the discovery button would not stay on even when I hit APPLY. So I went to Control, Services, SSDP and set it to automatic, as it was set to manual. Then I went to UpNp and set that to automatic, as it was disabled. Now I have a green light ALL THE TIME.
Do you also use the same router as the original poster?
i using huawei HG 256 and window 7.
however after follow the matter. i still got yellow light..
Port Mapping
Mapping Name Interface Protocol Remote Host External Start Port External end Port Internal Port Internal Host Enable Remove
name1 WAN2_INTERNET WAN2_INTERNET TCP/UDP 65535 65535 1 175.156.200.65 Enable
Settings
Type: Customization
Application    Choose... Domain Name Server (DNS) FTP server IPSEC Mail (POP3) Mail (SMTP) PPTP Real Player 8 Plus Secure shell server (SSH) Secure Web server (HTTPS) SNMP SNMP trap Telnet server TFTP Web server (HTTP)
Interface: WAN2_INTERNET
Protocol: TCP UDP TCP/UDP
Remote host:
External start port:
External end port:
Internal host:
Internal port:
Mapping name:
Enable Enable Disable
Submit
how i going to put the name into all the host or port.
Lance74, I’m not even sure what your asking, but it appears you want help with your router, not with bitcomet, so I suggest you ask at the routers forum.
